Get this instead of the 850 Pro http://au.pcpartpicker.com/product/w34NnQ/intel-600p-series-512gb-m2-2280-solid-state-drive-ssdpekkw512g7x1
And as an owner of a Deathstalker, I can say it's about the worst "gaming" keyboards I've had in my hands; I removed the keycaps once and they became stickier than a trump catchphrase. Had to coat them in glicerin to recover some amount of freedom to them, but they're still not anywhere near as good as from the box.
I dunno, maybe it's because I got the cheap one on the Deathstalker + Abyssus bundle. The Abyssus is a fine mouse, I enjoy using it and it's lasted a while and a bunch of osu!, but I would never give someone a Deathstalker.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/692854-first-build/#findComment-8884457
I have 2 deathstalkers, I love it. Bought them from razer online and they work fine.
https://linustechtips.com/topic/692854-first-build/#findComment-8884463
Perhaps I'm an outlier case or I removed the keycaps wrong. I'd still get the 600p instead, it will be faster.
Computer Specs:
https://linustechtips.com/topic/692854-first-build/#findComment-8884467
I'm going to use my deathstalker for another 16months or so, then I'll go onto a blackwidow or some mechanical keyboard so I can decide what I prefer. I have never used a mechanical but like membrane a lot and didn't want to change straight away from a laptop keyboard to a bigger membrane.
https://linustechtips.com/topic/692854-first-build/#findComment-8884473
