Hi, I'm getting my first rig soon and I'd like some advice on parts to get, and if I can get the total price any lower.
I'll be using the computer for gaming, 3D modelling and Photoshop painting, among other things. I'm fine with 1080p, but want to try 1440p. I haven't got a monitor, so I'm also open to suggestions on that front.
I have already narrowed down a list:
http://pcpartpicker.com/user/SouthTuna/saved/9Cz7P6
Help would be much appreciated. Thanks! :]
https://linustechtips.com/topic/692707-first-build/
PCPartPicker part list: http://pcpartpicker.com/list/HRTwkT
Price breakdown by merchant: http://pcpartpicker.com/list/HRTwkT/by_merchant/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($219.99 @ Newegg)
CPU Cooler: Corsair H100i v2 70.7 CFM Liquid CPU Cooler  ($96.99 @ Amazon)
Motherboard: MSI Z170-A PRO ATX LGA1151 Motherboard  ($74.99 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory  ($77.99 @ Amazon)
Storage: ADATA Premier SP550 240GB 2.5" Solid State Drive  ($60.99 @ Newegg)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive  ($118.99 @ SuperBiiz)
Video Card: Gigabyte GeForce GTX 1070 8GB G1 Gaming Video Card  ($399.98 @ Newegg)
Case: Phanteks ECLIPSE P400 ATX Mid Tower Case  ($59.99 @ Amazon)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($75.98 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($83.89 @ OutletPC)
Total: $1269.78
Generated by PCPartPicker 2016-11-18 12:40 EST-0500
I swapped the motherboard to shave off a bit of money, swapped the PSU (100W for $5, why not?), cheaper case, cheaper (but still good) SSD, and I changed the HDD to a faster WD Black, which is more expensive, but probably worth it.
do you really need a 2TB HDD though? at that point you may be better off with a NAS.
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/692707-first-build/#findComment-8883038
Actually, this might be better for what you are doing:
PCPartPicker part list: http://pcpartpicker.com/list/k2V3m8
Price breakdown by merchant: http://pcpartpicker.com/list/k2V3m8/by_merchant/
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($299.99 @ Newegg)
CPU Cooler: CRYORIG C7 40.5 CFM CPU Cooler  ($26.88 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.89 @ OutletPC)
Total: $1209.57
Generated by PCPartPicker 2016-11-18 12:44 EST-0500
it cannot support as large an overclock, but the extra threads will help with the production software.
Solitaire.
https://linustechtips.com/topic/692707-first-build/#findComment-8883058
Total: $1209.57
Why not change the PSU to something with decent quality?
26 minutes ago, valktuna said:
-Snip-
Get a EVGA G2 PSU instead.
https://linustechtips.com/topic/692707-first-build/#findComment-8883144
Total: $1209.57
Change that NEX PSU out for the G2. Same price and much better quality
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/692707-first-build/#findComment-8883146
Woops, I thought that was the G2, my bad.
http://pcpartpicker.com/list/hVD4BP
Solitaire.
https://linustechtips.com/topic/692707-first-build/#findComment-8883229
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory  ($77.99 @ Newegg)
Video Card: Zotac GeForce GTX 1080 8GB AMP! Edition Video Card  ($581.49 @ B&H)
Case: Deepcool TESSERACT WH ATX Mid Tower Case  ($29.99 @ Newegg)
Other: be quiet! PURE ROCK SLIM CPU Cooler 120W TDP - BK008 ($14.90)
Other: MSI Z170-A PRO LGA 1151 Intel Z1 ($74.99)
Other: Intel SSD 600p Series (512GB, M.2 2280 80mm NVMe PCIe 3.0 x4, 3D1, TLC) Reseller Single Pack ($132.99)
Other: TOSHIBA P300 HDWD130XZSTA 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Desktop Internal Hard Drive Retail Kit ($94.99)
Other: Intel Core i7-6700K 8M Skylake Quad-Core 4.0 GHz LGA 1151 91W BX80662I76700K Desktop Processor Intel HD Graphics 530 ($299.99)
Other: EVGA 750 GQ 210-GQ-0750-V1 80+ GOLD 750W Semi Modular EVGA ECO Mode Power Supply ($59.99)
Total: $1367.32
Generated by PCPartPicker 2016-11-18 13:27 EST-0500
$30 extra from your original build
majority is from buildapcsale
CPU-i7 6700k O.C. 4.6Ghz-Motherboard-Asus z170-a-RAM-24gb DDR4-GPU-EVGA GTX 1080 FE-Case-Corsair 400c (white)-Storage-HDD: 2xWD Blue 1TB SSD: PNY SSDSC120GLC709B121-510 120GB-PSU-1000 watt coolermax-Display-ASUS VG248QE Black 24" 1080p 144 Hz -Cooling-Corsair H115i-Keyboard-G.Skill KM780 Cherry MX blues (Red backlight)-Mouse-Logitech G602-Sound-Logitech 5.1 z506
Need a budget headphone for under 100$? Sennheiser HD 558 Headphones
Got a Skylake CPU (k) Here is a guide to OC it!
https://linustechtips.com/topic/692707-first-build/#findComment-8883252
