Recommend wireless HEADPHONE
-first : the budget it's a headphone so i must put it pretty high priority sub ~200 US dollar but it must worth every single penny
-second : comfortably must be over ear (my ear is sensitive , even a earbud could hurt my ear if put on over 10 minute) so the head phone "ear cup" must be big/soft enough
-third : durability , must last long , and don't be flimsy like a glass bowl , a small drop can't be serious!
-the sound , the sound must balance , crystal clear! , NOT like now days "overdose" bass boost or supper high pitch treble , i don't want my ear to bleed.
*IMPORTANT* have remove-able 3.5 audio jack so you could plugin when run out of battery
OPTIONAL have a remove-able mic and build in blue-tooth connection for mobile device (even though i mostly use a headphone for pc)
-thanks for helping :)
https://linustechtips.com/topic/692087-recommend-wireless-headphone/
