Very strange audio issue.
Go to solution Solved by RapidReece,
Make sure you have your motherboards audio drivers installed as the drivers should automatically stop the static from coming through.
I have noticed that my headphones are louder than usual. I was able to hear static in windows at around 30% volume. I didnt think anything of it and a restart seemed to fix the issue. But I restarted recently and my headphones are now absurdly loud. I hear static around 11 to 13%. I just have my headphones plugged into the front panel on my pc. Thanks for the help! :D
https://linustechtips.com/topic/691428-very-strange-audio-issue/
