Any help or input you have is appreciated, I no longer no what to try.
So, when I turn my computer on it boots into Windows 10 just fine, then roughly 50% of the time it will freeze within 5 minutes of the boot. I will have to force shutdown and when it boots back up it will be totally fine. Can play games for hours and hours no issues. Then I'll shutdown for the night and when I turn it on the next day the same issue will occur. Boot, freeze, force shutdown, boot fine.
If the freezing occurs it will always do it within 5minutes of booting windows and will do it regardless of what the pc is doing. Whether I'm playing a game, watching youtube, or just sitting at desktop.
What I've tried so far.
Different ram speeds, tried 2666, 2400, and 2133 (It feels like it happens less frequently at 2133, but definitely still happens)
Heard Avast can causes freezes while using steam. So I tried exceptions, disabling Avast, and finally I uninstalled nothing changed.
Riva Tuner in MSI Afterburner is known to cause freezing so I disabled that, still no change.
I tried different OC on my cpu and gpu, even though it shouldn't be the OC since I can run stable maxed
Since the issue occurs on Boot I disabled Windows 10 fast boot and hibernation no change.
I used to have a 750watt psu and a MSI 970 and the same issue was present so I don't think it's a power issue.
My Rig:
Intel 5820K OC to (4.5ghz at 1.275v)
Corsair H110i (280mm)
MSI x99a sli plus MOBO
16gb DDr4 G Skill 3000mhz in quad channel (currently running at 2133)
2way SLI EVGA 980ti Classified
500gb 850 EVO SSD
2TB WD Red HDD x2
Corsair 1200watt psu
OS=Windows 10 with Anniversary Update
Should note that my bios and all drivers are up to date.
I have been getting a failed to install Windows 10 update issue lately as well but unsure if that's related.
https://linustechtips.com/topic/690807-help-my-pc-keeps-freezing/
Boot into safe mode and see if it still freezes, could be viruses
My Rig:
500gb 850 EVO SSD
2TB WD Red HDD x2
warm it up if its freezing :P
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
your OS probably did not install successfully, since you keep getting fail to instal windows update.
Another is pretty much a virus, do what @Slottr suggested by checking the event log and see what the error is. If it is a virus, which I kinda doubt in certain regards, use TRONSCRIPT.
CPU-i7 6700k O.C. 4.6Ghz-Motherboard-Asus z170-a-RAM-24gb DDR4-GPU-EVGA GTX 1080 FE-Case-Corsair 400c (white)-Storage-HDD: 2xWD Blue 1TB SSD: PNY SSDSC120GLC709B121-510 120GB-PSU-1000 watt coolermax-Display-ASUS VG248QE Black 24" 1080p 144 Hz -Cooling-Corsair H115i-Keyboard-G.Skill KM780 Cherry MX blues (Red backlight)-Mouse-Logitech G602-Sound-Logitech 5.1 z506
Need a budget headphone for under 100$? Sennheiser HD 558 Headphones
Got a Skylake CPU (k) Here is a guide to OC it!
