I've been planning out my PC which I would use to do light software development and play games like Battlefield, I'm doing this while trying to keep the budget under $950 AUD. I'm eventually going to get another 8gb stick of ram and a 1TB HDD but until then this is my list:
http://au.pcpartpicker.com/list/rjzRzM
Also, will I be able to directly connect the motherboard to ethernet, or do I need a network card?
https://linustechtips.com/topic/689698-950-gaming-pc-help/
It looks OK overall. I would have suggested a larger SSD (240-256Gig) and a lower wattage (500watt) power supply, but you already have those parts. :)
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
https://linustechtips.com/topic/689698-950-gaming-pc-help/#findComment-8849887
