Python slightly complicated for loop
By
aikoels
in Programming
in Programming
Solved by fizzlesticks,
So you want to combine multiple lists and iterate over the result? If so you can just add the lists together.
test1 = ['test', 'peanut']test2 = ['pie', 'cake']for x in test1 + test2: print x
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
5
derekchan ·
1
2
6
5
7
kerriya ·
Posted in Cases and Mods14
play_circle_filled
Latest From ShortCircuit:
