4 minutes ago, xYowie said:
I currently have a g402 everything about it is decent other than the fact that i want the sides to go straight down like on the g pro and g403.
Which one would you guys recommend? my hand is 18.5cm long and 9cm wide and i use a claw grip.
G-Pro has low height so claw grip would be sexy. also RGB is sexy too
AMD Ryzen 7 7800X3D | Sapphire Pulse AMD Radeon RX 7900XT Triple Fan | G.Skill 32GB 2x D5 6000
https://linustechtips.com/topic/689460-g-pro-or-g403/#findComment-8847201
Statistically they are identical (tracking and response), but the pro has a bit more friction. The 403 is a bit larger in every direction but it's all about user preference so here are the size specs in mm.
403 -
Height 124
Width 64
Depth 43
Pro -
Height 116
Width 62
Depth 38
https://linustechtips.com/topic/689460-g-pro-or-g403/#findComment-8847206
