Hey Guys!
Some time ago I bought this mother board ( H8QME-2+) and I can't get it to post. I get one beep and nothing more. The fans spin up and the cpus do produce heat. According to the manual one beep means "Refresh (Ready to power up)", does this mean I have to jump another couple pins or do something else to boot it up? All help is appreciated! Thanks :)
ftp://www.supermicro.com/CDR-A+NVDA2_1.21_for_A+_nVidia_MCP55_platform/MANUALS/H8QM8(E)-2_1.0c.pdf
Samuel Edwards
- IT Engineer and Media Producer -
Religious theology diploma and over half a dozen certificates in Advanced Computing and IT.
Current Project:   Mineral Oil Cooled PC
Just trying to be friendly and help where I can. Have yourself a great day!
Use @SamuelJE for friendly tech help :)
Main PC - "The Genesis"
Mobo   -   Gigabyte GA-H170-Gaming 3
CPU     -   intel i5-6600K 4Ghz on water
GPU     -   MSI GTX970 "Red Dragon"
Case    -   Zalman Z11 Plus (Custom RGB Obviously, It's 2017 bro...)
OSD     -   Crucial 275GB M.2 SSD
SSD     -   Crucial 250GB SATA SSD
HDD    -    4TB WD Green x 2
Disp     -   LG ultra wide Gaming Monitor
Secondary PC - "Jonah"   (Mineral oil PC)
Mobo   -   Gigabyte GA-B250-DH1
CPU     -   intel i5-7500 Under Oil
GPU     -   Nvidia GTX 660 (Favorite and first ever GPU)
Case    -   A Fish Tank W/ Custom Engineered Mounting System (Custom RGB Obviously, It's 2017 bro...)
HDD    -    2TB WD Green
https://linustechtips.com/topic/687655-how-to-power-up/
do you have a gpu pugged in ? if so where is the monitor plugged into
RyzenAir : AMD R5 3600 | AsRock AB350M Pro4 | 32gb Aegis DDR4 3000 | GTX 1070 FE | Fractal Design Node 804
RyzenITX : Ryzen 7 1700 | GA-AB350N-Gaming WIFI | 16gb DDR4 2666 | GTX 1060 | Cougar QBX
PSU Tier list
https://linustechtips.com/topic/687655-how-to-power-up/#findComment-8827317
No I don't. Direct into the onboard vga.
Samuel Edwards
HDD    -    2TB WD Green
https://linustechtips.com/topic/687655-how-to-power-up/#findComment-8827320
does the monitor react? what cpu is on the board?
edit: just saw that it is an quad CPU opteron board (damn I want that) , what ram slots are populated ? (make shure the first cpu has ram in its 1st slot , wich is not necessarily the closest slot to the cpu
and maybe press the power button again or use a dedicated graphics card to see if the IGPU is shot
PSU Tier list
https://linustechtips.com/topic/687655-how-to-power-up/#findComment-8827326
