I need a pc case, with lots of room for hdd's as it will be a storage server, that can fit in this space.
WxHxD 33x14x10
I know its a tall order, but there has to be a case out there...
 i7-4770K, Corsair H100i, Asus Maximus VI Hero, Corsair Vengeance Pro 16GB, Samsung 840 120GB, 2xSeagate Barracuda 1TB, EVGA GeForce GTX 780 ACX Cooler, NZXT Phantom 820, Corsair Professional 750W 80 PLUS Gold, 2xASUS VH238H Build Log- http://bit.ly/1bWZKu6
https://linustechtips.com/topic/68695-case-for-a-shallow-shelf/
is this in inches? I'm asumming not in cm
Yes, in inches
https://linustechtips.com/topic/68695-case-for-a-shallow-shelf/#findComment-941567
Antec ISK110 VESA
that's even smaller than what you want, see if that fits the bill
Only fits 2hdds...need to be able to hold more...
https://linustechtips.com/topic/68695-case-for-a-shallow-shelf/#findComment-941603
can't you just have the case open so you can just put more and have them on the side or something?
or are you just a stickler for those kind of things? (won't blame you, I have the same issue :P)
Check out the build: Used to be Obot, now Lilith
Shameless: Me
https://linustechtips.com/topic/68695-case-for-a-shallow-shelf/#findComment-941662
I'm not sure the dimensions of it but one of those blocks for the Cooler Master Haf. I forget what they're called...I think those have plenty of room for HDDs though
http://www.amazon.com/Cooler-Master-HAF-Stacker-915R/dp/B00FB45WJ4/ref=sr_1_3?s=electronics&ie=UTF8&qid=1382659098&sr=1-3&keywords=haf+stacker+mod+tower
i5 4670k | Sapphire 7950 | Kingston 120GB SSD | Seagate 1TB | G.Skill Ripjaw X Series 8GB
PB238Q | Steelseries Sensei | Ducky DK9087 | Qck Heavy
Build Log: http://linustechtips.com/main/topic/44902-from-imac-to-my-own-creation/
https://linustechtips.com/topic/68695-case-for-a-shallow-shelf/#findComment-941699
wayyyy to deep
https://linustechtips.com/topic/68695-case-for-a-shallow-shelf/#findComment-941725
wayyyy to deep
 22.3 x 9.2 x 9.8 inches
How?
https://linustechtips.com/topic/68695-case-for-a-shallow-shelf/#findComment-941736
How?
the case is 22in deep, in order to fit it would have to be sideways...
https://linustechtips.com/topic/68695-case-for-a-shallow-shelf/#findComment-941978
Does that matter if it's a server? I don't know what else then :3
https://linustechtips.com/topic/68695-case-for-a-shallow-shelf/#findComment-942088
You need to list how many more, not just a guesstimate and have people put up ideas that can't meet your unknown requirement.
That being said you can always add drive holders to the PCI slots for even more than what the drive bays hold, like:
http://linustechtips.com/main/topic/4198-1-pcie-slot-25-drive-solutions/
I roll with sigs off so I have no idea what you're advertising.
This is NOT the signature you are looking for.
https://linustechtips.com/topic/68695-case-for-a-shallow-shelf/#findComment-942221
It will also act as my HTPC and the cabinet door is glass...
https://linustechtips.com/topic/68695-case-for-a-shallow-shelf/#findComment-942266
No other thoughts?
https://linustechtips.com/topic/68695-case-for-a-shallow-shelf/#findComment-943850
