Hello all -
I just realized that I am quite overdue on cleaning out the front air filter on my Bitfenix Ronin mid tower case. Heard the stock fans were pretty decent, so I left 'em in when purchased. Only thing is, I'm 6 months overdue on a routine dust maintenance for the filters and such. One problem - I have extreme difficulty taking off the front panel to get access to the filter, and this issue seems to be present in all Ronin case reviews, but in their case (figuratively and literally), it can be pried off using quite a bit of force. (I'm a relatively strong person, I promise)
Does anyone have the same issues with this particular case, and if so, are there any secret tips or a tool I could use? Case temps are starting to get toasty.
Thx
https://linustechtips.com/topic/686243-bitfenix-ronin-front-panel-issues/
