I just bought a XFX RX 460 to upgrade my PC, every time I reboot, the fan works perfectly fine, but as soon as I got into Windows, it stopped spinning, even until the GPU was overheating the fan still did not turn on. Plus, the fan works fine in BIOS
I have a Gigabyte motherboard, i3 6100 and 8G of RAM
https://linustechtips.com/topic/682107-xfx-rx-460-fan-problems/
Can you use software to force the fans to spin?
IM BACK BABY
https://linustechtips.com/topic/682107-xfx-rx-460-fan-problems/#findComment-8769656
So it should have pre-built in curves built in to ramp up when the card gets too hot. My curiosity when you say its overheating, are you meaning the screen goes dead, or the gpu shuts down, or are you saying it doesn't kick on when it reaches temps your uncomfortable with? Because one is a hardware or software failure, the other is lack of a realization that moderns cards run hot, and that goes double for AMD.
I would rather agree on what we share, than fight on what we don't. - Myself
FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/
https://linustechtips.com/topic/682107-xfx-rx-460-fan-problems/#findComment-8769704
Modern cardster don't run hot. We as consumers have become very picky about temps, which is different.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/682107-xfx-rx-460-fan-problems/#findComment-8769726
What I'm saying is 70-80c some people think is really hot for a gpu.
https://linustechtips.com/topic/682107-xfx-rx-460-fan-problems/#findComment-8771521
You're right, some people think 70-80C is too hot for a GPU, and I wholeheartedly disagree. I have seen no proof that chips last longer when working at <70 compared to 70-80. For temps higher than 85, yes there is a problem, and silicon can even become more unstable. But 70-80 is perfectly fine unless you like touching your GPU heatsink while running stress tests for some odd reason.
Computer Specs:
https://linustechtips.com/topic/682107-xfx-rx-460-fan-problems/#findComment-8796211
Yes I totally agree.
https://linustechtips.com/topic/682107-xfx-rx-460-fan-problems/#findComment-8798017
