I've been thinking of making a pretty cheap, mini-itx computer that I could use for lan parties and such. Here's the completed list: http://pcpartpicker.com/p/1S5e4 and I was wondering if any one could make any suggestions and what I should change. Thank you.
Edit: Thanks for all of the input. Here's the new list http://pcpartpicker.com/p/1S65k
CPU: Phenom II X4 965. GPU: Sapphire Vapor-X 7770. MoBo: AsRock 970 Extreme3. Ram: Corsair Vengeance 8gb 1600. PSU: Antec BP550. HDD: 1tb Seagate Case: RoseWill Challenger. CPU Fan: Arctic Freezer 7 Pro Rev 2. Monitor: Some crap gateway 1650x1050.
https://linustechtips.com/topic/68165-475-lan-party-build/
 Buy a single 4GB stick of RAM or a single 8GB stick if you can afford it.
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/68165-475-lan-party-build/#findComment-933381
Change the motherboard because it a bit on the expensive side. This may be an option: http://pcpartpicker.com/part/msi-motherboard-fm2a75iae53 . And a single stick of 4 GB of RAM for expandability later on.
Quote me to get a reply!
https://linustechtips.com/topic/68165-475-lan-party-build/#findComment-933391
Motherboard:  ASRock FM2A75M-ITX Mini ITX FM2 Motherboard  ($89.99 @ Microcenter)
Video Card:  XFX Radeon HD 7870 2GB Video Card  ($149.99 @ Newegg)
Total: $485.91
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-10-22 22:44 EDT-0400)
https://linustechtips.com/topic/68165-475-lan-party-build/#findComment-933393
Smart idea, thanks!
https://linustechtips.com/topic/68165-475-lan-party-build/#findComment-933398
Motherboard:  MSI FM2-A75IA-E53 Mini ITX FM2 Motherboard  ($84.99 @ Microcenter)
Total: $480.91
(Generated by PCPartPicker 2013-10-22 22:36 EDT-0400)
Anyways, the better 760K is cheaper, and the 7870 is better. Also, the i500 is a great PSU.
I wouldn't recommend that MSI board, some of the earlier revs blew up because of the terrible vrm design. I would recommend the ASRock or Gigabyte alternatives.
https://linustechtips.com/topic/68165-475-lan-party-build/#findComment-933411
Total: $485.91
https://linustechtips.com/topic/68165-475-lan-party-build/#findComment-933420
https://linustechtips.com/topic/68165-475-lan-party-build/#findComment-933443
By going with a 2x2GB kit, you are limiting the upgradeability of the machine.
https://linustechtips.com/topic/68165-475-lan-party-build/#findComment-933447
https://linustechtips.com/topic/68165-475-lan-party-build/#findComment-933456
True.
https://linustechtips.com/topic/68165-475-lan-party-build/#findComment-933567
