Triple 120mm rad would have quite a lot more cooling potential.
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/68145-h100i-vs-water-loop/#findComment-933015
A custom loop will always preform better. Really the only drawback is that it's quite the pain in the ass.
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/68145-h100i-vs-water-loop/#findComment-933036
i will just be cooling my cpu but i might cool a gou or 2 that im still debating on
If you're going to be cooling your CPU and GPU, it's a better choice to go with an expandable AIO (Swiftech H220/320, Cooler Master Eisberg, although it is not recommended if you're going for an extreme setup) or a custom loop.
https://linustechtips.com/topic/68145-h100i-vs-water-loop/#findComment-933074
quick help i will have a triple 120 with noctua nff12's  or should i get a h100i?
so far i'd say do nothing until you know what you will be doing now and not so much
in the future. with the lack of any information you have provided there will be no
defining answer.
your post about fans in another thread was just as empty. so going from a 360 rad to
a H100 means you might want to review these two links:
Water Cooling 101 - A good place for newbies to start
Water cooling FAQ - Some Basic Q&A
https://linustechtips.com/topic/68145-h100i-vs-water-loop/#findComment-933765
