I was wondering if anyone here might be able to help me.
I'm looking for some particular fans.
Specifically, UV LED-lit fans, not the UV reactive kind.
I want to add some UV effects to my watercooling loop, but I would rather not spend another $100-ish dollars on a UV light kit, if there's a fan out there that can do what I need.
Here's a pic that will hopefully help:
Replace the blue fans with some UV LEDs, and that's exactly what I'm looking for.
https://linustechtips.com/topic/679599-looking-for-a-fan/
sorry i can't help you find UV LED's as i live on an island at the bottom of the world; however if you can't find any it is not hard to purchase UV LED's and install them into your existing fans. I agree with the post above about LED strips. you can drill holes in your fans and hold LEDs in with hot glue. Just be careful of buying LED LASER diodes; they have a different lense/different shape of light that you might not want for your fans
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/679599-looking-for-a-fan/#findComment-8741891
