hi im hoping to get some idea on ram im looking for 64 gig quad channel ram 4x16 with good light desplays / leds for my build im looking for low timings around 15/15/15/32 and around 3600mhz for my extreme build pc plz post any suggestions you will have and ill look them up to see if they fit my build. ive seen some with good desplays but low mhz and others with good mhz but crap timing. money isnt a problem if i like they ill save and buy them. to give you some idea of what i like the best display wise ive seen is the (avexir Core Series - DDR4 i like that shape broken up look and music light pattern)
https://linustechtips.com/topic/678859-ram-help/
I recommend corsair dominator platinum with an aftermarket led kit.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/678859-ram-help/#findComment-8734572
