Posted October 17, 2016 I am pretty sure I did everything right, but when I power on the pc (by hitting the button on the mobo) the cpu cooler fan starts and then nothing happens after that. Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 Did you do a test boot? list of specs please also My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti [Under Construction] My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one. Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/#findComment-8711286 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 Author 3 minutes ago, Cereal5 said: Did you do a test boot? list of specs please also I did not. i7 6700k asus z170-a 212 Hyper Evo EVGA 650 GQ Gold Samsung 750 SSD G.Skill DDR4 16gb Phantom 410 case Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/#findComment-8711295 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 Have you plugged in the auxiliary power onto the motherboard? the extra 4 or 8 pin. If so, try moving the RAM around and if you have multiple sticks, try one at a time. Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/#findComment-8711299 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 7 minutes ago, mister_robot said: I am pretty sure I did everything right, but when I power on the pc (by hitting the button on the mobo) the cpu cooler fan starts and then nothing happens after that. Have another check over all the cables. Start again from scratch if you have to. Try turning it on with only the necessities plugged in. If it still no work, we'll have to do some digging Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/#findComment-8711302 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 Unplug everthing from the motherboard/PSU and leave just the CPU, cpu cooler, motherboard and power supply connected together and plug your monitor into your onboard graphics. try turning that on. report back with what happens My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti [Under Construction] My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one. Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/#findComment-8711303 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 Author 4 minutes ago, Sydlexic Deity said: Have another check over all the cables. Start again from scratch if you have to. Try turning it on with only the necessities plugged in. If it still no work, we'll have to do some digging So only the CPU and the MOBO are connected to the powersupply and there is still nothing. Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/#findComment-8711319 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 Author 5 minutes ago, Cereal5 said: Unplug everthing from the motherboard/PSU and leave just the CPU, cpu cooler, motherboard and power supply connected together and plug your monitor into your onboard graphics. try turning that on. report back with what happens The cpu cooler starts and then stops and thats it. Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/#findComment-8711321 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 Just now, mister_robot said: So only the CPU and the MOBO are connected to the powersupply and there is still nothing. This may seem silly - but are all the things are switched on? Are there at least two power cables connected to the mobo? Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/#findComment-8711329 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 Author 1 minute ago, Sydlexic Deity said: This may seem silly - but are all the things are switched on? Are there at least two power cables connected to the mobo? yeah the cpu and the motherboard. this is my first build so it may be something even more stupid Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/#findComment-8711334 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 1 minute ago, mister_robot said: yeah the cpu and the motherboard. this is my first build so it may be something even more stupid Alrighty then. The CPU is inserted properly? Is the RAM inserted correctly? (Try switching around if you have multiple sticks) Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/#findComment-8711339 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 did you line up the triangles on the CPU and motherboard when placing you CPU in the motherboard socket? try using a single stick of ram in one DIMM slot, then changing ram and dimm slots if it doesnt work My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti [Under Construction] My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one. Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/#findComment-8711344 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 Author Just now, Cereal5 said: did you line up the triangles on the CPU and motherboard when placing you CPU in the motherboard socket? yeah Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/#findComment-8711345 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 you didnt plug your CPU power cable into the VGA plug on your PSU? none of your cables are upside down? My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti [Under Construction] My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one. Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/#findComment-8711352 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 Does your PC power on then off? Or is it that the CPU fan twitches when you press the power on button? Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/#findComment-8711360 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 32 minutes ago, mister_robot said: I am pretty sure I did everything right, but when I power on the pc (by hitting the button on the mobo) the cpu cooler fan starts and then nothing happens after that. Instead of answering these questions do you mind sending a pic of the build making sure all cables show up Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/#findComment-8711400 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 1 hour ago, mister_robot said: I am pretty sure I did everything right, but when I power on the pc (by hitting the button on the mobo) the cpu cooler fan starts and then nothing happens after that. When you say nothing happens. Do you mean the CPU cooler fan starts and continues to spin? or it starts and then stops. And does the fan on you gpu start? Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/#findComment-8711651 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 Author 1 hour ago, ILUVDOGE said: Does your PC power on then off? Or is it that the CPU fan twitches when you press the power on button? The twitch. Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/#findComment-8711680 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 first of all, unplug everything, replug everything Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/#findComment-8712029 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 Author 12 hours ago, belfouf said: first of all, unplug everything, replug everything That worked! I was just dreading unscrewing everything and removing the cpu cooler but it worked in the end. Thank you. Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/#findComment-8714704 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 3 minutes ago, mister_robot said: That worked! I was just dreading unscrewing everything and removing the cpu cooler but it worked in the end. Thank you. glad, have fun Link to comment https://linustechtips.com/topic/676797-first-build-computer-wont-start/#findComment-8714726 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
