Quick question about power supply
Go to solution Solved by rn8686,
4 minutes ago, Number 29 said:
Any recommendations?
Budget? The B2 is better, but if you want the best, 550W G2 is great!. Ill link the PSU tier list, pick somthing from tier 1 or 2.
Hey guys, So I'm building a new pc here shortly and before I end up buying my final two parts I was planning on using my old power supply from my current PC which is an EVGA 600W supply. My only issue is I'm not sure if I'd need more wattage or if 600 would be more than enough for this build. Any help would be appreciated!
Build:
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($334.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($0.00)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  (Purchased For $0.00)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1600 Memory  ($0.00)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive  ($0.00)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (Purchased For $0.00)
Video Card: MSI GeForce GTX 1070 8GB Video Card  ($435.96 @ Amazon)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  (Purchased For $0.00)
Total: $770.95
Generated by PCPartPicker 2016-10-15 23:05 EDT-0400
https://linustechtips.com/topic/676292-quick-question-about-power-supply/
600W is enough, but what is the name of the PSU?
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
2 minutes ago, dexxterlab97 said:
What PSU? I would get a better one if I were you and 600 w is enough
The power supply I plan on reusing is the EVGA 600B
http://pcpartpicker.com/product/V9bp99/evga-power-supply-100b10600kr
I would recommend a new PSU, the B1 isnt very good.
PSU Tier List
My specs
PC:
Peripherals
2 minutes ago, wrathoftheturkey said:
Wattage is fine. But if it's just the 80+ one, I'd get a better one to avoid damaging your components
Just now, wrathoftheturkey said:
Budget? The G2's pretty damn good, but anything within your budget on the first two or three tiers of the PSU whitelist should be fine (let me get a link hold on)
Money isn't much of an issue, anything below around $80 would be ideal but if it's within a couple few dollars I wouldn't mind
PSU Tier List
My specs
PC:
Peripherals
i5-8600K -  Asus Strix Z370E - Asus GTX 1060 Strix - EVGA 650W P2 - Samsung 970 Pro 500GB - G.Skill TridentZ 16GB
