Posted October 15, 2016 I use a laptop with docking station & have all my cables in a box, which I have noticed is getting very warm to the point that PAT stickers are melting off My plan to build a Wooden box with cable brush & fans, Would it be safe (at my own risk) to take This Fan Speed Controller & connect the black & yellow wires to a 12V power adapter, if so what ampage would you recommend. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 15, 2016 10 minutes ago, j5-wyatt said: I use a laptop with docking station & have all my cables in a box, which I have noticed is getting very warm to the point that PAT stickers are melting off My plan to build a Wooden box with cable brush & fans, Would it be safe (at my own risk) to take This Fan Speed Controller & connect the black & yellow wires to a 12V power adapter, if so what ampage would you recommend. Linus once did a tech under $100 video where he had a laptop type PSU that ended in a Molex. The would probably be a safer option. ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est ¸„»°'´`'°«„¸`'°«„¸¸„»°'´ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 15, 2016 As long as you solder and wrap every connection it would be fine but if you have to buy a power supply you might as well get one with a molex connector. https://www.amazon.com/gp/product/B000MGG6SC/ref=pd_sim_23_2?ie=UTF8&pd_rd_i=B000MGG6SC&pd_rd_r=6EJP5HXKCD70QKEZQSM0&pd_rd_w=XSTXx&pd_rd_wg=aQTo6&psc=1&refRID=6EJP5HXKCD70QKEZQSM0 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 15, 2016 Author Thanks - Didnt even cross my mind that Mains Power to molex would exist ! ? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 17, 2016 A much easier solution would be to buy any of the widely available laptop coolers that exist on the market. Oh... everything is in a box? How...? Yeah just buy a molex power brick.. http://www.kr4.us/power-supply-12v5v-2a.html?gclid=CMPA7baW4s8CFQ90fgodT4kNYQ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
