My rendering workstation is equipped with 4 Intel Xeon processors (88 cores total plus threads). However, even under full load, only 3 of the Xeon processors are used. To test, I ran multiple CPU stress tests at the same time, which took a while but eventually got all the CPUs under load, except for the fourth. The system was used by a coworker before, and he said all the processors were working fine. What's going on? The processors are the E5-2699 model. I really hope it's not broken, because those processors aren't cheap.
https://linustechtips.com/topic/675076-cpu-problem/
You can't use more than 2 e5 2xxx cpus in a board you need e7 4xxx or e7 8xxxx
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/675076-cpu-problem/#findComment-8693051
3 minutes ago, atrooper said:
I'm not sure that's the model they were all working together a week ago.
Does it see the cpu in the bios and they are all enabled? Has the program you are using or Windows had any updates which could be broken or changed a profile or setting?  Is the cpu dead?
Rig Specs:
https://linustechtips.com/topic/675076-cpu-problem/#findComment-8693070
