Low GPU usage F1 2013
Go to solution Solved by Samskip,
Re-installing windows fixed everything.
So since yesterday I've been getting about half the framerate (around 55fps) in F1 2013 of what I got before (110fps) on my 670. Afterburner is showing GPU usage of around 35-55%. I've installed the latest beta drivers and re-installed F1 2013 but i doesn't help.
Any suggestions?
Thanks in andvance.
Intel i7-870  //  MSI GTX 670 PE       ///       Intel i7-4500U  //  GT720M
https://linustechtips.com/topic/67326-low-gpu-usage-f1-2013/
I'm running fine but i'm running  7970
CPU: FX-8350 Cooler: NZXT Kraken X60 w/2X NF-A14 FLX MoBo: Asus M5A99FX Pro Rev 2.0 Memory: 8GB G.Skill Sniper@1720 GPU: Sapphire Dual-X HD7970@1100/1500 Storage: Samsung 840 120GB(OS), Seagate Barracuda 1TB 7200 64MB PSU: Sparkle 850W Gold Case: Corsair C70 Military green w/ Solid window Keyboard: Ducky Shines 3 (MX Blues), Razer BlackWidow 2013 Ultimate Mouse: Corsair M90,M65 w/ Vengeance MM600
https://linustechtips.com/topic/67326-low-gpu-usage-f1-2013/#findComment-921277
I'm not getting any problems. I'm fairly certain the game recently got patched so that could be it
Edit: Did you turn V-Sync on?
I had V-sync on before but not anymore as my framerate is fluctuating around 60. I don't think the patch caused the issues because I didn't have this problem when I already had the patch.
https://linustechtips.com/topic/67326-low-gpu-usage-f1-2013/#findComment-921303
  • 9 months later...
