Hi All,
I'm (fairly) new here.
I was wondering if anyone can help me decide on a steering wheel and pedals combination for playing Euro Truck SImulator 2 on the PC with?
Prferably not mega expensive as I'm only just starting out but decent enough quality and if possible force feedback?
I've read about the T150 from Thrustmaster being good especially with the force feedback but I'd like opinions on said wheel and pedals or reccomendations on cheaper/better alternatives.
Kind Regards,
Jack Hubbleday
:D
Don't forget to @me / quote me for a reply =]
https://linustechtips.com/topic/671822-steering-wheel-pedals/
I use the T150 and its a great entry level wheel. I would say FFB is a must for any wheel. If you go into somewhere like PC World/Curry's if in the UK you can also get a T150 cheaper than anywhere else. Not sure how that works but mine was £30 under the lowest price I could find online.
I use my T150 for truck sim and racing including iRacing and its got me up to B Class license for online oval racing so far OK, no issues.
cheers,
Lewis
https://linustechtips.com/topic/671822-steering-wheel-pedals/#findComment-8659075
2 hours ago, theninja35 said:
You could also go with the Thrustmaster TMX which has a few more buttons and is all black instead of the T150's blue/black color scheme. They're about the equivalent price, though.
cheers,
Lewis
Thanks guys,
great help!
Hope we can play sometime?
Jack x
https://linustechtips.com/topic/671822-steering-wheel-pedals/#findComment-8659638
