In need of help ASAP
Goaterino
Okay i have been having serious issues with my computer this past week, I was able to log onto windows but it would black screen and take the whole night to get to the desktop and from there i could do nothing with it... After trying everything i could think of and recommendations from people i decided to just reinstall windows through the reset option, next thing i know blue screens, saying BAD_SYSTEM_CONFIG_INFO and does this constantly. It does not let me try to repair the drive through windows also.. So now I'm pretty much fed up, can anyone help?
Just now, wrathoftheturkey said:
Try booting a Linux distro and checking if the drive failed that way.
Never used linux can i have a link to download it?
From the sounds of it your hard drive is nearing the end if a clean install isn't helping. I would make backups of your data immediately if you haven't already and place an order for a new drive. You can also try booting into Safe Mode if you haven't tried that already.
If you need a LiveCD I recommend you download this and boot to the GUI: http://www.ubcd4win.org/
-KuJoe
Okay i ordered a new drive a few days ago because i thought this was the problem... The only other computer i have on hand is a mac so how do i go about this, like i have never used a usb to install an os.
Okay well turns out on the installation of windows 10 through reset, deleted all of my windows reg hive ...
