Im helping my brother build a new PC. His budget is $800CAD, excluding HDD and SSD which he will reuse from his old PC. I was thinking something like this-
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($264.99 @ Newegg Canada)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($69.99 @ Newegg Canada)
Memory: G.Skill Ripjaws V Series 8GB (2 x 4GB) DDR4-2133 Memory  ($49.99 @ Newegg Canada)
Video Card: XFX Radeon RX 470 4GB HS Triple X Video Card  ($284.99 @ Newegg Canada)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply  ($64.99 @ Newegg Canada)
Total: $734.95
Generated by PCPartPicker 2016-10-03 19:48 EDT-0400
The only things im not sure on are the mobo and gpu. Im assuming the psu is enough for the build, and I doubt he will ever sli or anything like that. He will not be overclocking, and the case isn't chosen yet since im leaving that up to him. He's also going to order everything off of Newegg.
Edit: His goal is to play Bo3 on high settings, and other AAA games like GTA 5.
https://linustechtips.com/topic/670722-800cad-build/
3 minutes ago, aSpoink said:
sli
lol its an AMD card so Crossfire
Try for a GTX 1060 instead. Much better performance, while staying under 800CAD
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814487260&cm_re=gtx_1060-_-14-487-260-_-Product
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/670722-800cad-build/#findComment-8647430
Would go with a 1060 3G over the 470 for the same price.
PCPartPicker part list
Memory: G.Skill Aegis 8GB (1 x 8GB) DDR4-2400 Memory  ($42.99 @ Newegg Canada)
^1x8GB stick for easier upgrade to 16gb
Video Card: EVGA GeForce GTX 1060 3GB 3GB SC GAMING Video Card  ($279.99 @ Newegg Canada)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($69.99 @ Newegg Canada)
Total: $727.95
  • Quote people's post else they won't know you replied.
Crapware | 4670k | Hyper212X | GSkill RipjawsX 16GB | Sapphire R9 280x VaporX | 840EVO 120GB | 1TB BLACK + BLUE
Logitech G102 | Corsair K70 MX Brown | HyperX Cloud
https://linustechtips.com/topic/670722-800cad-build/#findComment-8647466
2 minutes ago, aSpoink said:
Do you know if there is a difference between the 6400 and the 6500? Or is it just the clock speed on the 6400 is lower.
400-500mhz lower clockspeed, otherwise its the same.
https://linustechtips.com/topic/670722-800cad-build/#findComment-8647467
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($258.95 @ Vuugo)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($64.98 @ DirectCanada)
Memory: Patriot Signature Line 8GB (1 x 8GB) DDR4-2133 Memory  ($42.99 @ NCIX) save the extra slot for later.
Video Card: EVGA GeForce GTX 1060 6GB 6GB GAMING Video Card  ($334.69 @ DirectCanada)
Case: Deepcool TESSERACT BF ATX Mid Tower Case  ($39.99 @ Newegg Canada) my case recommendation, pretty good for the price.
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($58.98 @ NCIX) just as good but higher wattage and modular.
Total: $800.58
Generated by PCPartPicker 2016-10-03 20:08 EDT-0400
https://linustechtips.com/topic/670722-800cad-build/#findComment-8647479
8 minutes ago, herman mcpootis said:
-snip-
Nice af
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/670722-800cad-build/#findComment-8647509
So what about something like this?
Memory: Crucial Ballistix Sport LT 8GB (1 x 8GB) DDR4-2400 Memory  ($44.99 @ Newegg Canada)
Video Card: Asus Radeon RX 480 4GB Dual Video Card  ($299.99 @ Newegg Canada)
Total: $744.95
Generated by PCPartPicker 2016-10-03 20:32 EDT-0400
https://linustechtips.com/topic/670722-800cad-build/#findComment-8647564
Total: $744.95
swap out the s12ii for the cx550m, would recommend the gtx 1060 6gb or rx 480 8gb instead. otherwise its fine.
https://linustechtips.com/topic/670722-800cad-build/#findComment-8647593
So this is fine? The SeaSonic unit was the same price as the cx550m so I thought that would be better.
Video Card: Zotac GeForce GTX 1060 6GB 6GB Mini Video Card  ($334.99 @ Newegg Canada)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($89.99 @ Newegg Canada)
Total: $804.95
Generated by PCPartPicker 2016-10-03 20:54 EDT-0400
https://linustechtips.com/topic/670722-800cad-build/#findComment-8647656
the cx550m is $30 cheaper and slightly better after rebates. everything else is fine.
https://linustechtips.com/topic/670722-800cad-build/#findComment-8647663
https://linustechtips.com/topic/670722-800cad-build/#findComment-8647988
