Hey,
I'm having trouble with my triton ax pros that I bought second hand a few years ago. I had the problem about 12 months ago so stopped using them but just a few days ago they were working fine however they seem to have the same problem again now. I think the problem is in the power supply for the headset as when I plug in the headsets box thing to the power it flashes on and off repeatedly and when connected to the headset make a clicking noise (as if it were turning on and off repeatedly). I live in the uk and the plug Has one of those interchangeable faceplates which I have with the U.K. Faceplate on.
if anyone has any ideas about why this is happening, a fix for the solution or if the worst comes to the worst recommendations for where to buy a new power supply or if it's worth just getting a new setup Id be happy to hear.
Thanks,
         Biccers
https://linustechtips.com/topic/670560-power-problems-with-my-headset/
1 hour ago, Biccers said:
Any help would be appreciated.
Seems like the box has problem with the supply of power. Either the box or the power cables are causing you problems. Try with other cables at first before buying a new box.
Also, I recommend using headphone+mic instead of those "gaming headset".
