What should i replace or add ?
My budget is ca .800 Euros.
I will add a case but  i haven´t found one ,yet.
(i need a mainboard with dd live / dolby digital live support. If someone thinks i should use another one please consider that :))
Parts:
https://www.mindfactory.de/shopping_cart.php/basket_action/load_basket_extern/id/9375752210cde8eaea7daa36cbbfec567ffae5a1a883dd53034
https://linustechtips.com/topic/666698-first-pc-build-need-help/
34 minutes ago, tt7753 said:
You could get a cheaper PSU like an XFX TS or Seasonic S12ii giving room in the budget to get a better air cooler like the Hyper 212 EVO or Cryorig H7.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/666698-first-pc-build-need-help/#findComment-8605757
