Hello, i recently bought gigabyte r9 280x. However i am having some trouble with its temperature. If i select auto on the amd CCC controls for the fan speed the card sits around 42-45C and 65-70 under load. Even if i tried 100% speed while idle i still couldnt get it to go under 39C. Every other card ive had has stays under 35C idle so i am just wondering if thats normal. I have decent air flow and the case is clean. My i5 2500k at 4.3 sits around 25C idle and 35-40 under load so the surrounding temps are fine. I also noticed that the only hot part of the card is the metal bit which is supposed to make it more rigid. Is this normal? Also, every once in a while when i boot the windows it will not detect the card but it does show pictures as if there are no drivers, im assuming thats because of the beta drivers at the moment. Thanks for the help in advance.
https://linustechtips.com/topic/66548-gigabyte-r9-280x-problem/
n/a. I accidently posted here.
My System:
CPU: i7 4790k @ stock GPU: EVGA GTX 780 FTW MB: ASUS Z97-PRO (Wi-Fi ac) RAM: CORSAIR Dominator 16GB (2 x 8GB) DDR3 2133 CPU Cooler: Corsair H100i SSD: 2 256 GB Samsung 840 Pros in RAID-0 HDD: Western Digital 500 GB Black, Seagate Barracuda 3TB 7200 RPM 64MB Cache PSU: Cooler Master V850 80 Plus Gold Case: Fractal Define R4
https://linustechtips.com/topic/66548-gigabyte-r9-280x-problem/#findComment-909603
it doesn't really matter what the idle temp is as long as the load temp is ok with it is in your case  :) . beta drivers can be a bit strange sometimes. if you use the latest none beta ones is it still strange?
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/66548-gigabyte-r9-280x-problem/#findComment-909664
well, i cant find any drivers for this card that are not beta. both online and on the disc come up as beta. Just one more thing about the temp, when its idle and i touch the card the only place its hot is the meta bar on top side of the card thats meant to make it more stable.
https://linustechtips.com/topic/66548-gigabyte-r9-280x-problem/#findComment-909692
If you want you could redue the thermal compound normally cards ship with teriable thermal compound and changing it could bring your temps down
CPU: Intel Core i7 4790k CPU Cooler: Corsair H100i Chassis/Case: Fractal Design Arc Midi R2  Motherboard: Asus Z87-Deluxe RAM:  Team Vulcan 2x4Gb(2133Mhz)  Video Card: Asus 7970 Direct CU II Custom Rom (150% Power, 1100 core 6Ghz Memory)  Power Supply: Fractal Integra R2 750 Watt  Keyboard: Cooler Master Quick Fire Rapid (MX Blue Switches)  MouseCorsair M90 Storage: SX900 128Gb, Seagate 1TB 7200RPM, WD Green 1TB 7200RPM   MY OLD BUILDLOG
The Fastest 8350 @5.33Ghz with a score of 9.16pts in Cinebench 11.5
https://linustechtips.com/topic/66548-gigabyte-r9-280x-problem/#findComment-909906
Its Normal. Not a Problem unless you find it a problem.
That "Hot Bar" would be the heatpipe, thats what transfers the heat using liquid inside the chamber.
My 7950 @ 1.109 idles at 31*c
My 7950 bios 2 is a 7970's @ 1.256 idles at 38*c <-- seen both 7900 models use this voltage
Its your Default Voltage, its probably set closer to 1.256 being a 7970 rebadge 280x.
Whatever monitoring program you use, it should tell you the voltage, or maybe put the card in use, and have GPUZ in the background collecting stats you can check.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/66548-gigabyte-r9-280x-problem/#findComment-910381
you have nothing to worry about at 40c on idle
now, if you were hitting 90-100 with no dust buildup on load then you would have a issue
Old Rig | Cpu - Intel Q6600 @ 3.5Ghz | Cooler - Cooler Master Hyper 212+ | Mobo - Asus Rampage Extreme | Ram - 8GB OCZ Gold 1600mhz | Gpu - 2x Asus DK Radeon HD 4870 1GB (Crossfire) | Psu - Corsair TX750W | Case - Thermaltake Element G
New Rig | Cpu - Intel 4770K @ 4.5Ghz | Cooler - Swiftech H220 | Mobo - Asus Z87 Deluxe | Ram - 16GB Kinston Hyper X Beast @ 2400Mhz | Gpu - Sapphire R9 290X | Ssd - Kingston Hyper X Beast 3K 240GB | Psu - Corsair HX850W | Case - Fractal Design Define R4
https://linustechtips.com/topic/66548-gigabyte-r9-280x-problem/#findComment-910518
