2 minutes ago, Chandres said:
What specification of Pumo would I need for, 1 GPU, 1CPU 1 240mm Radiator and a 360mm Radtiator?
d5 laing all the way :) the question which type you want is up to you ;)
ASUS Maximus VII Hero | i7 4790K OC 4.8GHZ | 4x8GB 2400MHz MSI GTX 1070 alphacool eiswolf gpx pro
Samsung 850 EVO 520GB + Corsair 525gb + 275gb SSD  2TB Seagate Barracuda | 8TB Seagate Archive
Cooler Master HAF-X 942 | EVGA Supernova 1000W 80+ Platinum | Custom watercooling loop (gpu+cpu)
360mm+180mm rad and 10 fans | Swiftech D5 mcp655-B
https://linustechtips.com/topic/661081-what-pump-would-i-need/#findComment-8547116
https://linustechtips.com/topic/661081-what-pump-would-i-need/#findComment-8547120
6 minutes ago, Chandres said:
are thoose enough for 2 radiators
they are the only once that maintain the flow with 2 or more radiators :)
https://linustechtips.com/topic/661081-what-pump-would-i-need/#findComment-8547165
