Hello peoples,
I have problems with my laptop, and I was wondering if there is anyone who would know how to fix it.  First of all, the laptop that I use is an Asus Rog G751JT.  I have been using this laptop for about a year, and the problem started a month ago.  The problem that I have been having is the battery seems to not be calibrated, and any attempt for me to do so (draining the battery completely and charging it again) worked for about a week, but then it became uncalibrated again.  It seems this way because the battery that is usually either green to indicate that it is full, or orange to indicate that it is charging, but instead, it is just flashing between the two, which it normally does not do.  The second sign of the battery being uncalibrated is when I go over to the battery icon on my taskbar, it states that the battery is always 98% and not charging, and when I unplug my laptop, it only lasts a few minutes before completely draining, when it used to last for at least an hour.
This has been really annoying, and it doesn't allow me to take my laptop anywhere, so if anyone has any information or help, it would be nice to receive some.
(keep in mind that the battery of this laptop isn't really removable)
https://linustechtips.com/topic/660872-laptop-battery-not-working/
