1 minute ago, Kosta-Nedeljkovic said:
Hello,
I got new PC and it has H81m-K motherboard.Since it has no onboard WIFI,i need to buy one.I wonder if there is special sockets for that too or is most of those cards compatible with motherboards.
Thank you :)
Since that board has PCIe 1x, I would recommend this card:
 https://www.amazon.com/Gigabyte-GC-WB867D-I-Bluetooth-Adapter-Computer/dp/B00HF8K0O6/ref=s9_simh_gw_g147_i1_r?_encoding=UTF8&fpl=fresh&pf_rd_m=ATVPDKIKX0DER&pf_rd_s=&pf_rd_r=F5VQXTAP4X8FBAZQY0W1&pf_rd_t=36701&pf_rd_p=cca70e28-a3b0-4f0d-b847-0ae9cb54558a&pf_rd_i=desktop
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/658602-which-wireless-card/#findComment-8517159
Is that PCI express?
Yep, if you look at the motherboard, there are 2 small slots below where the graphics card plugs in, this is where that card would plug in at.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/658602-which-wireless-card/#findComment-8517181
Just now, Kosta-Nedeljkovic said:
well thank you :)
Not a problem. That wireless card also has bluetooth, so if you have an available USB 2.0 header on the board, you could plug it in and have bluetooth connectivity as well.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/658602-which-wireless-card/#findComment-8517195
