Hey everyone,
I'm planning on getting a 850w Thermaltake ToughPower RGB PSU that is going to go in a white Corsair 760t case. I don't think the sleeved cables they come with will look well with the case theme and was hoping you could recommend an alternative (preferably white or black). Any help would be appreciated since I've never messed with PSU cable mods.
Thanks!
https://linustechtips.com/topic/657870-power-supply-cables/
10 minutes ago, HungryHamster said:
Hey everyone,
Thanks!
I don't believe I know anyone that makes standard replacement cables for the unit so you will need to get some custom ordered, I believe Cable Mod might have that available through their Configurator but double check.
https://linustechtips.com/topic/657870-power-supply-cables/#findComment-8507004
