Thats a really open question.
here are some things that might help people help you:
What do you want to use it for?
Do you care about aesthetics?(i.e. leds ,tempered glass windows,etc)
Does this include peripherals?
What kind of form factor?
Does loudness matter?
Do you have any computer parts already?
For 1500$ i would suggest looking at this video:
https://linustechtips.com/topic/657801-need-help-with-a-build/#findComment-8506115
Currency? what is your purpose, gaming? do you need just the tower, or do you also need monitor, keyboard, mouse, speakers/headset, etc?. What sort of aesthetic or colour scheme do you want? What resolution and fps do you intend to play at? Do you have any preference for special features like M.2, NVME, USB 3.1 or USB type C/Thunderbolt and so on.
Answer those questions and I shall recommend for you a build based on that criteria.
https://linustechtips.com/topic/657801-need-help-with-a-build/#findComment-8506122
