I'm in the process of a mini itx build and am curious if I were to get the ASRock Z77E-ITX, which features a single x16 PCIe slot (for my graphics card) and a mini PCIe slot, if I could utilize the mini PCIe through a mini-PCIe-to-PCIe adapter to run a Elgato HD60 Pro capture card.
Alternate suggestions are welcome!
Possibly, you talking about x1? Not mini pcie?
Nevermind, just looked it up, just never seen mini pcie before.....weird
https://www.google.com.au/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#safe=strict&q=mini+pcie+to+pcie+x1+adapter
Just now, chrisbritish said:
I'm curious if the adapter would slow data transfer or anything of the sort. I called Elgato and they said they don't support and hadn't even thought about trying that.
If it is a mitx system where would you even put the capture card? Most likely there wouldn't be any room inside the case.
As mpcie is only pcie x1 it might slow down transfer rates.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
