Just now, Kazetana said:
Go for the Noctua NH-U14S 49 GBP on Amazon uk or 67 GBP for the NH-D15 if you can afford it (and if it fits).
I have a Phanteks Enthoo pro m case. I hate the colour of the noctua fan ;):/ I'll look at some video's on it!
https://linustechtips.com/topic/655695-need-an-air-cooler/#findComment-8462085
1 hour ago, GeorgeKellow said:
(I know I should make an other thread)
No, you shouldn't. It's much better to keep the discussion intact as opposed to revisit it across two posts.
What are you cooling?
https://linustechtips.com/topic/655695-need-an-air-cooler/#findComment-8464494
https://linustechtips.com/topic/655695-need-an-air-cooler/#findComment-8464577
