Im looking to build a pc which runs csgo at 300 fps and already have some parts for a build
450 dollars i need to pickup a motherboard, Ram and finally a cpu.
Already got a gtx 950 and looking to upgrade once i got a good cpu and stuff
leave suggestions please
https://linustechtips.com/topic/655673-450-usd-build-help/
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($179.88 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($150.88 @ OutletPC)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($64.99 @ NCIX US)
Total: $420.63
Generated by PCPartPicker 2016-09-06 12:31 EDT-0400
I don't have the slightest clue why you'd get a 4460 when Skylake has a far wider upgrade path and only a $2 difference. Can drop the CPU cooler & switch to 1x8GB of of RAM in favor of a 6600K if you're interested in overclocking, but do note you'll need to get a cooler at some point.
https://linustechtips.com/topic/655673-450-usd-build-help/#findComment-8460907
Total: $420.63
16gb ram? a bit overkill for cs go ,unless he's gonnna be runnin chrome
get 8gb and stay with that its cheaper and current games dont need much ram power , unless u wanna start youtube than 16gb would be good for editing
https://linustechtips.com/topic/655673-450-usd-build-help/#findComment-8460978
Total: $420.63
I don't have the slightest clue why you'd get a 4460 when Skylake has a far wider upgrade path and only a $2 difference. Can drop the CPU cooler & switch to 1x8GB of of RAM in favor of a 6600K if you're interested in overclocking.
oh and also a z170 mobo with a non k sku?
https://linustechtips.com/topic/655673-450-usd-build-help/#findComment-8461059
No reason not to get 16GB. OP stated no preference as long as it stays under $450, and could very well have other interests. If he doesn't plan on overclocking (no one is budgeting for coolers except me, I guess.) then Z170 is even a waste. Chrome isn't that bad, but nice try.
Z170 isn't a problem, what if he gets into overclocking and replaces the CPU down the line? See the second sentence of my first post.
https://linustechtips.com/topic/655673-450-usd-build-help/#findComment-8461090
