difference between seagate normal & barracuda drives?
just wonder what the difference between these two drives is and if its worth getting the barracuda over then normal one even though I can get a good open box deal on the normal one.
https://www.amazon.com/dp/B005T3GRLY/ref=olp_product_details?_encoding=UTF8&me=
https://www.amazon.com/Seagate-BarraCuda-3-5-Inch-Internal-ST3000DM008/dp/B01IEKG4NE/ref=dp_ob_title_ce
At a core level, they're the same drive. Both are 3 TB, both use SATA 3, both have 64MB of cache, and both are 7200 RPM. That second one is just a version with Seagate's newer branding scheme. Comparing the Serial Numbers (ST3000DM001 for the first drive and ST3000DM003 for the second one) you'll notice the only difference is the last digit, which likely signifies production variants of the same product. Go ahead and go with the newer version, assuming that it's the same price, but otherwise they're the same :)
Project Tomahawk:
CPU: Intel Core i7 4790k
Motherboard: Asus Maximus VII Hero
CPU Cooler: Corsair H100i
Memory: 16GB Kingston HyperX Fury 1866 Mhz
GPU: Asus Strix RX 480
PSU: Corsair RM1000
Storage: 2x Western Digital 2TB Enterprise + 240GB Crucial M500 SSD
Case: Corsair Air 540
Additional: Cablemod C-Series black/red kit, SP120, AF140 and AF140 w/ red LED's all around
Project Frankenstein:
CPU: AMD FX 6100
Motherboard: MSI 970 SLI Krait Edition
CPU Cooler: Cooler Master Hyper 212 EVO
Memory: 8GB G.Skill Ripjaws X 1866 Mhz
GPU: MSI R9 280 3G Twin Frozr
PSU: Seasonic M12II EVO 620W
Storage: Western Digital 1TB Enterprise + 240GB Partiot Torch SSD
Case: Fractal Design Define S
Sheila (Server):
Dell R210:
CPU: Intel Xeon x3450
Memory: 12GB Crucial ECC 1600 Mhz
Storage: Seagate 3TB Constellation
Marvin (Server)
Dell R210ii
CPU: Intel Xeon E3 1230v2
Memory: 12GB Crucial ECC 1600Mhz
Thank you. This is what I thought and I just wanted to double check since harddrvies aren't my area of expertise lol
Yep, no problem! :)
Project Tomahawk:
PSU: Corsair RM1000
CPU: AMD FX 6100
Sheila (Server):
Dell R210:
Marvin (Server)
Dell R210ii
