hd 7970 flash questions
Go to solution Solved by TheRandomness,
It should be fine.
Hello, so i own a sapphire dual-x hd7970. I was so desperate to undervolt it without afterburner because i run multiple operating systems.
Stock bios never worked properly with vbe7 editor. So i downloaded a newest sapphire hd 7970 vapor-x bios i modified that and flashed it.
Vuala the card is undervolted and runs cooler now and the bios added a memory voltage control support. It seems stable.
Btw i checked vrm and memory support beforehand and it matched. I even searched for pcb photos and they looked same.
Do you guys think that the only ddifference between these cards is just a different cooler?
And is it safe to run it like this in a long term ?
https://linustechtips.com/topic/652707-hd-7970-flash-questions/
