Need some recommendations on a good CPU + Mobo combo, weather it's Blue or Red, it needs to be budget so i7's probably out the window, willing to spend max £200 for CpU and £120/150 for Mobo but any cash you can shave off is appreciated. I know with a bit of tinkering in the Bios you can OC the non K Intel processors. So not fussed about that either. Need to be a good multi tasking CPU.
I use most Adobe CC programms and game at mid to high quality on most popular games.
My Main Driver:
Intel i3-6100
Asrock Z170 Extreme4
8Gb DDR4-2400 Crucial Sport Lt
Buying AMD Rx 480
Phanteks P400 in white
Evga 650 Modular
https://linustechtips.com/topic/651406-cpumobo-help/
Best that fits the budget i5-6500
https://www.amazon.co.uk/dp/B0136JONRM/?tag=pcp0f-21
Any mobo will fit with a 120p - 150p range. You can get a Z mobo for oc but if you don't want it then here
https://www.amazon.co.uk/dp/B014QPFJAU/?tag=pcp0f-21
If you want I can get i7 6700 (non K) for 250 pounds and get a cheap mobo. Total cost of mobo and cpu should not go over 320 (200+120)
CPU: https://www.amazon.co.uk/dp/B0136JONG8/?tag=pcp0f-21
Mobo: https://www.amazon.co.uk/dp/B01A9GHD3G/?tag=pcp0f-21
https://linustechtips.com/topic/651406-cpumobo-help/#findComment-8369471
Useful stuff, never seen that Mobo before, will definitely check it out! thanks for the UK links as well, helps :)
My Main Driver:
Intel i3-6100
Buying AMD Rx 480
Evga 650 Modular
https://linustechtips.com/topic/651406-cpumobo-help/#findComment-8369482
Interesting, however you lose out on features with the cheaper Mobo, it's a possibility however,
Good insight :)
My Main Driver:
Intel i3-6100
Buying AMD Rx 480
Evga 650 Modular
https://linustechtips.com/topic/651406-cpumobo-help/#findComment-8369602
