I just got my new ram. It's stock frequency is 3200 MHZ so naturally I over clocked it to 3200 MHZ however when I do the screen starts acting weird with whites lines that com on the screen randomly. This only happens after i oc it over 2700MHz , 2700 is stable. I have tried ramping the ddr voltage to 1.4 but that still did not fix it. Does anyone know why this is happening? Thanks.
XTREME I7 GRANDIS TRIDENT SUPERNOVA ECLIPSE PC++:
CPU           ✧   i7 6700K  @ 4.5 GHz 1.31 VCore
COOLER   ✧   SilentiumPC Grandis
MOBO       ✧   MSI Z170A GAMING PRO CARBON
RAM          ✧   16Gb Trident Z's 3200 MHz
GPU          ✧    Gigabyte GTX 980 ti XTREME
SSD           ✧   Samsung 850 Evo 250 GB
PSU           ✧   EVGA SuperNova G2 650W
CASE         ✧   Phanteks Eclipse P400S [Black]
Use:
✧ Game designing, Programming, Compiling, 3D rendering and of course Gaming
https://linustechtips.com/topic/651219-over-clocking-memory-problems/
yeah it's unstable. you could try lowering (high number) the timings and see if that helps. do you have a cpu overclock?
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
Did you try just enabling XMP, without manually touching anything?
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
I manually changed everything
Use:
Yes I have a cpu oc. This happened to my old ram too. Also how do I set the timings?
Use:
in the bios.
Just now, vorticalbox said:
in the bios.
Yeah but I don't see an option for it. When I enable xmp it sets it to 16-18-18-38
Use:
