Hi guys! I just built my first pc, and everything seems to be working well except the GPU. When i start games it always runs them at 5-10 fps. I dont know the reason behind this, the fans on the gpu are spinning and the leds are working. I also have my hdmi cable in the GPU. The graphics card is one that i got 3 days ago, so it should run smoothly. Specs are as followed
CPU: Intel core i5-4690K
CPU Cooler: CM hyper 212 evo
GPU: RX 470 nitro 8GB GDDR5
RAM: HyperX fury 1600MHz 8gb ddr3
SSD: HyperX fury 240 gb SSD
PSU: Corsair RM550x
Case: CM storm scout II advanced gaming
Motherboard: MSI Z97 Gaming 5
Thankfull for any and all help
https://linustechtips.com/topic/651083-gpu-running-games-at-low-fps/
Would you post Radeon Settings screenshot?
As well post Wattman screenshot after running a game.
What game is it btw?
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
28 minutes ago, ZiCe CornerStone said:
Nvm guys fixed the problem, uninstalled my drivers and installed them again, now everything is working perfectly!
If you face any more random hiccups, uninstall AMD and Nvidia(if you had installed them at any point) drivers using Display Driver Uninstaller from guru3D.
Remember to select AMD and uninstalll and then select Nvidia and uninstall(or vice versa, just have to uninstall both) since its specific uninstall(doesn't uninstall both AMD and Nvidia drivers at once.
