Hey guys,
Please help me I'm little bit confused between getting a Intel core i7 6700 or 6700k. I will be using the PC to edit videos, little bit of 3d rendering and motion graphics. Primary software's Premiere Pro CC, After Effect CC, Da vinci Resolve, C4D.
If I go with 6700k which Z170 board should I go with for a stable overclock and new features. And How much of performance difference will be there in between 6700 and 6700K?
In my budget I'm thinking of getting RX470 GPU or GTX960 GPU. Which one should I go with? If RX470 will it out perform GTX960?
My Budget is 1,100,00 INR Buying in India. I want one 1080P monitor, keyboard and mouse in this budget
Thanks guys. Looking forward to your responses.
https://linustechtips.com/topic/650380-1200-build-need-help/
get a 6700k. even if you don't overclock it its a HUGE boost in performance. clock speed is absolutely everything. don't go for a 960, its not worth the price right now. look at the 1060(3GB) or wait for a 1050 maybe. I'd grab an RX470 since its an amazing card for the money:)
https://linustechtips.com/topic/650380-1200-build-need-help/#findComment-8359173
