Hey,so i bought today a new cooler for my cpu cause the old one broke and when the new cooler was installed,i turned on the pc to check the temperatures.I looked at them a while and saw how the temperatures are jumping from 30 to 40+ and down again to 30.
Please help,this didnt happen with stock intel cooler!!!
https://linustechtips.com/topic/650261-cpu-temperature-jumping-up-and-down/
Do you have enough thermal compound/ did you remove the sticker on the bottom of the new cooler?
CPU: Intel Core i7-7700 GPU: NVIDIA GTX 1070 Cooling: N/A  Motherboard: N/A  Ram: 32GB
HDD: 4TB RAID 1 Array (two 4TB)  PSU: N/A Case: N/A OS: Windows 10 Mouse: Something Something Logitech
Keyboard: Razer Blackwidow 2016 Headphones: Audio Technica ATH-M40X Speakers: ??? Monitor: 2 x HP 22cwa  Phone: OnePlus 3T (T-Mobile Network)
1 minute ago, Brad Lemon said:
i kinda think that there is too much thermal compound(dont know if possible) and yes i removed the sticker
Eh, Too much isn't really a thing with thermal compound, too much means its spilling everywhere. Maybe your cooler is adjusting fan speeds depending on the temp?
It's nice how you don't tell us anything about your specs or the kind of load you are putting it through and then expect us to help... We can try and aid you, but you need to give us some context first.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
it doesnt really matter what the idle temps are. the load temps are the only thing thats important.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
