I have just recently invested in better audio equipment. I have the Akg k7xx that runs off of the Schiit Vali, and a nice set of speakers. The problem I was having is that if I have them plugged in at the same time only one option comes up in the sound tab labelled speakers. Beack when I had a usb headset there would be two option that I could switch between. I wanted them to show as two different options so I could just change the default audio device, and not have to crawl under my desk to unplug one of them for the other to work. Thanks
https://linustechtips.com/topic/649551-need-help-setting-up-my-audio/
How are the things connected to the computer?
If my assumption is correct you're not using two diferent audio devices anymore, so that's why you can't switch between them in Windows.
Can't you just connect your speakers to the pre-amp out on the Vali 2? That way you just need to unplug your headphones for your speakers to play.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
I have the amp connected to a 3.5mm jack in the back of my pc, and I have the speakers in the front 3.5mm jack. Sorry for the late reply
I think that's the problem, and I think Volbet is correct, your computer now 'sees' them as one since they're both running off your onboard audio. I'd have had this issue too but have this issue licked due to my having an Oppo HA-1 which has multiple inputs and acts as a pre-amp as well. For you, perhaps the simplest solution, something like the below:
https://www.amazon.ca/Headphone-Splitter-Stereo-3-5mm-Adapter/dp/B003JUWQLY
Not an expert, in fact, something of a newb, so wait for others to coinfirm or refute this suggestion....
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
Thanks for the reply, if I used this the computer would recognize them as two separate devices? If there is even a chance that it would, I wouldn't mind shelling out the $3 for the cable. Thanks again.
No, but with this, you don't have to unplug either the Vali or your speakers (which I assume to be some sorta powered ones). IF you speakers uses stereo minijack -> RCA inputs, then you simply plug the minijack from your speakers to one of the two female minijack sockets, the other would go to your Vali (assuming you have a stereo minijack to L/R RCA plugs for your Vali as well). As long as you have only either the Vali  or speakers on at any one time, it shouldn't be a problem.....only downside is that since the audio signal from your mobo is split into two ways, you may find volume to be a bit lower than with simply plugging either the Vali OR speakers plugged in.
Thanks for the info
