So I wanted to step up from the stock cooler and pre-installed fans and go for some proper cooling. But I am unsure if my motherboard can handle all the fans, so I turn to you guys with more experience.
The motherboard is a MSI B85M-E45, and the fans I am looking at are:
2x Noctua NF-F12 PWM 120mm
3x Noctua NF-A14 PWM 140mm
1x Noctua NH-U9S
Perhaps a bit overkill, but my pc overheating kinda scares me and I don't want to live in constant fear.
https://linustechtips.com/topic/646456-air-cooling-help/
11 minutes ago, daniielrp said:
The board only seems to have 1x cpu header and 1x sysfan header, so you'll need a fan controller ideally. Unless you run them from your psu but that would mean 100% all the time = loud!
https://www.komplett.no/product/649597/datautstyr/vifterkjoelingvannkjoeling/viftestyring/nzxt-sentry-mesh-fan-control-525-bay
like this?
https://linustechtips.com/topic/646456-air-cooling-help/#findComment-8319025
2 minutes ago, norwegianpotato said:
If you have the slot for it then okay, but usually fan hub or splitter is more convenient.
https://linustechtips.com/topic/646456-air-cooling-help/#findComment-8319041
18 hours ago, norwegianpotato said:
If you have the space then yeh a controller can be useful, but for most cases Ichi is right a splitter or hub is better.
https://linustechtips.com/topic/646456-air-cooling-help/#findComment-8323150
That one is OK if you want to manually control every fan manually, but I would recommend something like this
https://www.nzxt.com/products/grid-plus-v2
Core i7 7700k Kabylake stock + Kraken x52 | ASUS Z170-A | 8GB DDR4 2133MHz HyperX | ASUS GeForce GTX 1060 STRIX 6GB | 250GB SSD Samsung 850 EVO + 2TB HDD WD RE4 | Seasonic X-Series 650w | Corsair 460x RGB  | Win 10 Pro 64 bit | Corsair M65 PRO RGB Mouse | Corsair K70 RGB RapidFire
https://linustechtips.com/topic/646456-air-cooling-help/#findComment-8323172
Is that danielle in your profile photo?...
Emma Roberts;)
https://linustechtips.com/topic/646456-air-cooling-help/#findComment-8328521
