Help choosing new monitor
Lucaz97
Hi all,
I'd like to get rid of my 800*600 4:3 monitor 9_9, buy a new one, and use the one that is currently my main monitor as second one (20" 1600x900).
With my pc I mostly do work tasks. Primary Eclipse and Android Studio, more occasionally Unreal Engine 4 or Unity (but still I work on the code part not the graphics). I also do a little of web design and IoT.
It happens I play games but I am not a demanding player.
So, my budget is not really clear yet (I should get some money for a job for the end of the month but not sure of the ammount........ ) therefor I was looking for a 100 to 300 € range (the best would be having two options, one in the low and one in the high... )
I am also not sure about the resolution, for what I saw there are also 1440p monitors in my range... But you gotta also look at my graphics card, in my signature (yep is the worst part of my pc).
So, money saved will go in the graphics card (probably a 1060 3gb or a 470 idk yet, but my tasks dont really require gpu beasts).
Those are the ones I've looked at so far and liked (please if suggesting look on amazon.it or taocomputer.eu):
https://www.amazon.it/Dell-210-AEOM-P2416D-Monitore-Argento/dp/B00X4W3VVG/ref=sr_1_3?ie=UTF8&qid=1471604911&sr=8-3&keywords=2k+monitor
https://www.amazon.it/Asus-VX24AH-2560x1440-Frameless-Certified/dp/B00QLL01BA/ref=sr_1_1?ie=UTF8&qid=1471604982&sr=8-1&keywords=monitor+2k
https://www.amazon.it/Samsung-24F350F-Monitor-Full-Nero/dp/B01BCF0006/ref=sr_1_3?ie=UTF8&qid=1471605067&sr=8-3&keywords=monitor+freesync
https://www.amazon.it/Samsung-S24F356FHU-LCD-Monitor-23-5/dp/B01EX7KSPM/ref=pd_sim_sbs_147_3?ie=UTF8&psc=1&refRID=91VGY3FH5JEJM3ZKR1T3
Thanks in advance for the time dedicated.
Intel i7 6700k @4.6 1.330v  cooled with H110i GT // 16Gb Kingston Fury DDR4 ram @2133MHz // Rx 480 Nitro+ // 2TB + 1 TB Hdd  // 250 GbSSD // on an Asus Z170-A // powered with Corsair RM750i // all  inside a Corsair 600C
No one? :(
CPU: i7 5930k  |  Motherboard: EVGA X99 Classified  |  RAM: 32 GB Crucial DDR4  |  GPU:  R9 290 Reference Tri-Crossfire w/Kraken g10 mod  | Case: Corsair 780t  |  Storage: Sandisk 960GB SSD, Crucial 960GB SSD, 128GB Sandisk SSD, Seagate 2TB Hard Drive, Seagate Archive Drive 8TB, HGST Deskstar 4TB  |  PSU: Rosewill Gold Lightning-1300, Display(s): Nixeus Vue 24"144Hz FreeSync, 50in TV, Yiynova MVP22U(V3) Tablet Monitor w/ Mechanical Arm  |  Cooling: Cosair H55, H105, 2*Kraken X41  |  Keyboard:  Rosewill Mechanical Brown Keyboard| Mouse: MX Master, G602  | Sound:  Sennheiser HD 700, Westone W40, SoundBlaster e5, Fiio e18
Personally I would just save until I could buy a new graphics card and monitor at the same time. Not sure how a card like that ended up in your system but I would definitely do it justice by going with a rx 470 or another card in your price range and a 1080p monitor. Or even save more and buy a better GPU and 1440p monitor
So even for not heavy graphics task a 1440p requires a powerful gpu :( ?
2 hours ago, iLoiter said:
I agree, but when programming having a nice height allows to read a decent ammount of lines at one time without having to continue scorrling...
Is a 29 " wide going to have a height equal or higher than a 20" 16:9 ?
EDIT: ok is basic math, it is slightly higher, then would be nice ... but i was considering some 24-25 hd or qhd and those would be higher
I would reccomend this one then since you can just swivel it vertically. That way you can have 29 inches of height for coding.
https://www.amazon.it/LG-25-25UB55-B-IPS-Monitor/dp/B00KTH1D2I/ref=sr_1_2?ie=UTF8&qid=1471710219&sr=8-2&keywords=ultrawide+monitor
Edited by iLoiter
Well no it doesn't but your rig is quite capable and you said you do play some games so why not have a decent GPU. The rx470 you already suggested is probably fine for what you need
Just now, iLoiter said:
I would reccomend this one then since you can just swivel it horizontally. That way you can have 29 inches of height for coding.
This solution is kinda great!
And for the graphics card I've seen here: http://www.taocomputer.eu/shop2007/scheda.asp?id=34918 RX 470 225€
and http://www.taocomputer.eu/shop2007/scheda.asp?id=34903 RX 480 254€
If the prices are so closes I will porbably go with the 480, also I just got a call for two jobs  I should start soon and get done by the end of September so I will start getting the monitor so i can work on it and then buy the gpu
Thank you guys!
When I built it I gave no budget to the gpu cuz I had this friend with this gpu that would have borrowed it to me, thinking that pascal was just around the corner... Then  pascal is freacking expensive and I was waiting for some reviews to pick the right bang for the buck..
