2 hours ago, Artiom916 said:
Hey guys, so the first time i turn on my computer every day there is one case fan that makes alot of noise. But then when I turn it off and on again its perfectly fine. What is going on with it? Any ideas?
Does it sound like its just spinning really fast or sort of like a lawn mower or something not pleasant?  If it sounds like a lawn mower check if the fan is not running into something, i had this problem and it was running into that stupid yellow tag on the 212 evo cord.
Ariana Grande's Leaked Nudes!!!111!11!
Ayyyyyy
Gaming Rig:     CPU:  i5-4690k  Cooler:  H80i  Mobo:  MSI z97 PC MATE  RAM:  16gb Fury White  Storage:  1TB WD + 120gb Fury SSD  GPU:  GTX 970  Case:  NZXT S340  PSU:  NEX 650W  Keyboard:  K65 RGB  Mouse:  Mionix Naos 7000  Headphones:  ATH-M50x  Monitor:  2x VN248h-P + 1x MG248q  Setup Photo:  (To come)
https://linustechtips.com/topic/645342-case-fan-going-bad/#findComment-8307421
1 hour ago, Artiom916 said:
Well the fans are always running at max speed cause they plugged into PSU, but it sounds like the fan shakes or jiggles. Im not sure. But after turning the computer off then on again it works fine.
hmm thats weird... I would check the screws to make sure theyre tight, what fans do you have? (btw quote me next time so i get a notification)
Ayyyyyy
https://linustechtips.com/topic/645342-case-fan-going-bad/#findComment-8307442
Im not sure what fans I have, the screws are tight. Maybe they spinning to fast? Also if thats the cars is they a way to slow them down when they connected to PSU.
https://linustechtips.com/topic/645342-case-fan-going-bad/#findComment-8307524
No you cant fan control them with a psu, the only way to control them is through your mobo if it supports fan controlling or buying a fan controller.
Ayyyyyy
https://linustechtips.com/topic/645342-case-fan-going-bad/#findComment-8307533
