hey,
so a couple months ago i got an ultra wide monitor for my setup, a LG 25UM58-P to be specific, now i heard that on some lg displays you can split the screen into the two different inputs im i just imagining this? is it all a dream? if it is true how do i do it?
I lurk a lot
https://linustechtips.com/topic/644860-split-display-on-ultrawide/
My old 29UB55 and my current 34UM95 (both ultrawides) both have the support for it. The feature is called PBP and splits screen in half, one half being one input and other half being second input. You can choose both in settings and even choose which input's audio will be played through display.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
how did you turn on this PBP mode?
I lurk a lot
Look into the monitor settings.
Yea, your display doesn't have that feature. On LG website, it is marked in one of the two ways: PBP (Picture by Picture) or Dual Link Up.
