Help merging 2 SSD's
Go to solution Solved by Julian5,
1 hour ago, HDERAZI96 said:
How is it ? Does it worth it ?
I have the m14 r2, got it for free and is amazing, costumer support is amazing and the build quality is good
Hello,
Guys I'm thinking to change from MacBook Pro 9,2 to Alienware 17 R3 and I am sure most of you knows in Alienware there is M.2 x2 Slots and 1 SATA. Anyway my question is:
What if I installed two of Samsung 850 EVO - 500GB - M.2 SATA.. for OS boot and games,.. Can I merge them together so they became 1 TB ??
Also, I will install another Samsung 850 EVO - 500GB - 2.5-Inch SATA For Data like pics or backups. Or maybe the opposite ??!!
Advanced thanks ;).
https://linustechtips.com/topic/644194-help-merging-2-ssds/
yes you can in the windows disk manager
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/644194-help-merging-2-ssds/#findComment-8294673
Just google, How to merge drives on windows
Elemental
Laptops
https://linustechtips.com/topic/644194-help-merging-2-ssds/#findComment-8294701
Just now, HDERAZI96 said:
Found it,... Thanks a lot ;)
welcome, I tried to do it once and it worked. just dont do it with removable drives or you will fuck up your OS
Elemental
Laptops
https://linustechtips.com/topic/644194-help-merging-2-ssds/#findComment-8294720
Don't worry I won't do that,,... Actually I will clone the original HDD then I will put all the listed SSD's in thats Alienware,.. You know Video/Photo editing and gaming requires too much storage.. The issue I will be facing is that How could I change those SSDs after doing. x.x
https://linustechtips.com/topic/644194-help-merging-2-ssds/#findComment-8294740
Google can help you... xD Im on alienware too
Elemental
Laptops
https://linustechtips.com/topic/644194-help-merging-2-ssds/#findComment-8294745
Elemental
Laptops
https://linustechtips.com/topic/644194-help-merging-2-ssds/#findComment-8295208
