Building my first pc need help
Go to solution Solved by Rainin,
What about the Cables to the screen?
Are they also coming from the motherboard? If so, you need to connect them to the GPU as most motherboards have PCI set to default.
Do you have the cables connected to your Graphics card?
Motherboard: MSI X99A Sli Plus,       RAM: Corsair CMK32GX4M4A2400C14 Vengeance LPX (32GB),
CPU: Intel i7-5820K,      GPU: EVGA GeForce GTX 960,       PSU: Corsair Gaming Series GS600,
HDDs: 2x Toshiba P300 1TB 64MB 7200RPM,      SSD: Crucial BX200 240GB
All inside a Corsair Carbide 300R with a Corsair CW-9060007-WW Hydro Series H60.
Have a good day everyone!
Here are some things to try:
Make sure graphics card is seated properly in the PCIe slot.
If the graphics card requires power, make sure the power cables are connected properly.
Make sure the monitor is set to the right input.
Try connecting to the onboard video to see if you get a signal.
i7 4790k | GTX 970 | 16GB
That's all you need to know. It's a beast.
Check this thread:
ZamoRIG 2.0:
Processor: AMD Ryzen 7 1700 @ 3.9GHz
Cooling: DeepCool Captain 240 RGB + 2x Corsair ML120 fans
Graphics Card: Gigabyte GTX 1070 G1 Gaming x2
Motherboard: Asrock X370 Gaming K4
RAM: 2x8GB DDR4 G Skill Ripjaws V Grey @ 2800MHz
SSDs: 2xPatriot Ignite M.2 240GB
HDD: WD Black 1TB + WD Green 2TB
 PSU: Corsair RM750
Case: Corsair Carbide 400C
ZamoRIG “Portable”:
Processor: AMD Ryzen 5 1600 @ 4GHz
Cooling: Corsair H80i
Motherboard: Gigabyte AB350N Gaming WiFi
RAM: 1x16GB DDR4 Corsair Vengance  @ 2400MHz
SSD: Patriot Ignite M.2 240GB
HDD: 2TB 2.5” Seagate HDD
PSU: Corsair TX650M
Case: Siverstone SG13
It still didn't work, any other ideas
4 minutes ago, ElZamo92 said:
Check this thread:
Try the above. :)
I got it to work by plugging the hdmi into th graphics card, thanks?
Ah, nice!
Good Job!:)
