Hi,
so i am not 100% sure if i am in the right section for that, so sry if not.
here we go...
it is not my computer but i do my best to explain the problem.
this is how the setup looks like: http://imgur.com/hk8qXf1
when he is streaming, he use a second computer with a capture card (AVermedia ExtremeCap U3). to be able to use his main display at a high refresh rate (144hz) and use the capture card, he has to clone his main display with the capture card rather than use pass-through.
how the problem looks like: http://imgur.com/7ts7hGP
game in fullscreen (left primary monitor 1920x1080) extends into the monitor on the right (secondary monitor)
game: miscreated
the problem is, when attempting to play miscreated in fullscreen mode with the capture card enabled, it sets the game to this strange resolution that overlaps into the second monitor and leaves all the menu options or UI in game
unclickable. having the game in windowed mode is fine, but that's not an option due to how poor the performance in windowed mode is.
https://linustechtips.com/topic/642053-strange-fullscreen-resolution-issue/
3 hours ago, elpiop said:
Try alt tabbing out of the game
i am sorry, i see i forgot more informations.
ok so first a list of system details:
CPU: Intel i7-6700k
RAM: 16GB DDR-4 RAM
GFX: EVGA GTX 1080 FTW
OS: Windows 10 Home 64-bit
nvidia display driver version: 368.81
Main Display: Acer Predator 24in (1920x1080@144hz)
2nd Display: LG 29in Ultrawide (2560x1080@60hz)
Cap Card: AVerMedia ExtremeCap U3 (1920x1080)
what we have tried:
al tabbing
setup manually the resolution in game setting file
playing around with, fullscreen, windowed mode, borderless windowed mode
reinstall the game
disable secondary monitors
disable g-sync
but what i saw while i wrote this, i reminded me on something..
it is a evga gpu and maybe he use evga precision, that would explain the low fps in windowed mode. evga precision has a option to clock down in desktop mode and could still be on if he play in windowed mode.  need to wait for his answer to confirm that.
would not solve the fullscreen problem, but he could play it at least windowed with good fps.
